Version: Latest-3.3
CREATE USER
Description
Creates a StarRocks user. In StarRocks, a "user_identity" uniquely identifies a user. From v3.3.3, StarRocks supports setting user properties when creating a user.
tip
Only users with the user_admin role has the privilege to perform this operation.
CREATE USER [IF NOT EXISTS] <user_identity>
[auth_option]
  • user_identity consists of two parts, "user_name" and "host", in the format of username@'userhost'. For the "host" part, you can use % for fuzzy match. If "host" is not specified, "%" is used by default, meaning that the user can connect to StarRocks from any host.
    For the naming conventions of usernames, see System limits.
  • auth_option specifies the authentication method. Currently, three authentication methods are supported: StarRocks native password, mysql_native_password, and "authentication_ldap_simple". StarRocks native password is the same as mysql_native_password in logic but slightly differs in syntax. One user identity can use only one authentication method.
    auth_option: {
    IDENTIFIED BY 'auth_string'
    Authentication methodPassword for user creationPassword for login
    Native passwordPlaintext or ciphertextPlaintext
    mysql_native_password BYPlaintextPlaintext
    mysql_native_password WITHCiphertextPlaintext
    authentication_ldap_simplePlaintextPlaintext
Note: StarRocks encrypts users' passwords before storing them.
  • DEFAULT ROLE <role_name>[, <role_name>, ...]: If this parameter is specified, the roles are automatically assigned to the user and activated by default when the user logs in. If not specified, this user does not have any privileges. Make sure that all the roles that are specified already exist.
  • PROPERTIES sets user properties, including the maximum user connection number (max_user_connections), catalog, database or session variables on the user level. User-level session variables take effect as the user logs in. This feature is supported from v3.3.3.
    -- Set the maximum user connection number.
    PROPERTIES ("max_user_connections" = "<Integer>")
    -- Set the catalog.
    PROPERTIES ("catalog" = "<catalog_name>")
    -- Set the database.
    PROPERTIES ("catalog" = "<catalog_name>", "database" = "<database_name>")
    -- Set session variables.
    PROPERTIES ("session.<variable_name>" = "<value>", ...)
    tip
    • PROPERTIES works on user instead of user identity.
    • Global variables and read-only variables cannot be set for a specific user.
    • Variables take effect in the following order: SET_VAR > Session > User property > Global.
    • You can use SHOW PROPERTY to view the properties of a specific user.
Example 1: Create a user using a plaintext password with no host specified, which is equivalent to jack@'%'.
CREATE USER 'jack' IDENTIFIED BY '123456';
Example 2: Create a user using a plaintext password and allow the user to log in from '172.10.1.10'.
CREATE USER jack@'172.10.1.10' IDENTIFIED WITH mysql_native_password BY '123456';
Example 3: Create a user with a ciphertext password and allow the user to log in from '172.10.1.10'.
CREATE USER jack@'172.10.1.10' IDENTIFIED BY PASSWORD '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9';
CREATE USER jack@'172.10.1.10' IDENTIFIED WITH mysql_native_password AS '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9';
Note: You can get the encrypted password using the password() function.
Example 4: Create a user who is allowed to log in from a domain name 'example_domain'.
CREATE USER 'jack'@['example_domain'] IDENTIFIED BY '123456';
Example 5: Create a user that uses LDAP authentication.
CREATE USER jack@'172.10.1.10' IDENTIFIED WITH authentication_ldap_simple;
Example 6: Create a user that uses LDAP authentication and specify the distinguished name (DN) of the user in LDAP.
CREATE USER jack@'172.10.1.10' IDENTIFIED WITH authentication_ldap_simple AS 'uid=jack,ou=company,dc=example,dc=com';
Example 7: Create a user who is allowed to log in from the '192.168' subnet and set db_admin and user_admin as the default roles for the user.
CREATE USER 'jack'@'192.168.%' DEFAULT ROLE db_admin, user_admin;
Example 8: Create a user and set its maximum user connection number to 600.
CREATE USER 'jack'@'192.168.%' PROPERTIES ("max_user_connections" = "600");
Example 9: Create a user and set the catalog of the user to hive_catalog.
CREATE USER 'jack'@'192.168.%' PROPERTIES ('catalog' = 'hive_catalog');
Example 10: Create a user and set the database of the user to test_db in the default catalog.
CREATE USER 'jack'@'192.168.%' PROPERTIES ('catalog' = 'default_catalog', 'database' = 'test_db');
Example 11: Create a user and set the session variable query_timeout to 600 for the user.
CREATE USER 'jack'@'192.168.%' PROPERTIES ('session.query_timeout' = '600');
