Version: Candidate-4.0
hex_decode_string
This function performs the opposite operation of hex().
It interprets each pair of hexadecimal digits in the input string as a number and converts it to the byte represented by the number. The return value is a binary string.
hex_decode_string(str);
str: the string to convert. The supported data type is VARCHAR. An empty string is returned if any of the following situations occur:
  • The length of the string is 0 or the number of characters in the string is an odd number.
  • The string contains characters other than [0-9], [a-z], and [A-Z].
Returns a value of the VARCHAR type.
mysql> select hex_decode_string(hex("Hello StarRocks"));
| hex_decode_string(hex('Hello StarRocks')) |
| Hello StarRocks |
Keywords​
HEX_DECODE_STRING
