Version: Latest-3.5
format_bytes
Converts a byte count into a human-readable string with appropriate units (B, KB, MB, GB, TB, PB, EB).
This function is useful for displaying file sizes, table sizes, memory usage, and other storage-related metrics in a user-friendly format. It uses 1024-based calculations (binary prefixes) but displays units as KB, MB, GB for simplicity and familiarity.
This function is supported from v3.4.
VARCHAR format_bytes(BIGINT bytes)
  • bytes: the number of bytes to format. BIGINT is supported. Must be a non-negative integer value.
Returns a VARCHAR value representing the formatted byte size with appropriate units.
  • For values less than 1024: returns the exact number with "B" (bytes)
  • For larger values: returns a formatted string with 2 decimal places and the appropriate unit (KB, MB, GB, TB, PB, EB)
  • Returns NULL if the input is negative or NULL
Usage notes
  • The function uses 1024-based (binary) calculations internally (1 KB = 1024 bytes, 1 MB = 1024² bytes, etc.)
  • Units are displayed as KB, MB, GB, TB, PB, EB for user familiarity, though they represent binary prefixes (KiB, MiB, GiB, etc.)
  • Values greater than or equal to 1 KB are displayed with exactly 2 decimal places
  • Byte values (less than 1024) are displayed as whole numbers without decimal places
  • Negative values return NULL
  • Supports values up to 8 EB (exabytes), covering the full range of BIGINT
Example 1: Format various byte sizes.
SELECT format_bytes(0);
-- 0 B
SELECT format_bytes(123);
-- 123 B
SELECT format_bytes(1024);
-- 1.00 KB
SELECT format_bytes(4096);
-- 4.00 KB
SELECT format_bytes(123456789);
-- 117.74 MB
SELECT format_bytes(10737418240);
-- 10.00 GB
Example 2: Handle edge cases and null values.
SELECT format_bytes(-1);
-- NULL
SELECT format_bytes(NULL);
-- NULL
-- 0 B
Example 3: Practical usage for table size monitoring.
-- Create a sample table with size information
CREATE TABLE storage_info (
table_name VARCHAR(64),
size_bytes BIGINT
INSERT INTO storage_info VALUES
('user_profiles', 1073741824),
('transaction_logs', 5368709120),
('product_catalog', 524288000),
('analytics_data', 2199023255552);
-- Display table sizes in human-readable format
table_name,
size_bytes,
format_bytes(size_bytes) as formatted_size
FROM storage_info
ORDER BY size_bytes DESC;
-- Expected output:
-- | table_name | size_bytes | formatted_size |
-- | analytics_data | 2199023255552 | 2.00 TB |
-- | transaction_logs | 5368709120 | 5.00 GB |
-- | user_profiles | 1073741824 | 1.00 GB |
-- | product_catalog | 524288000 | 500.00 MB |
Example 4: Precision and rounding behavior.
SELECT format_bytes(1536);       -- 1.50 KB (exactly 1.5 KB)
SELECT format_bytes(1025); -- 1.00 KB (rounded to 2 decimals)
SELECT format_bytes(1048576 + 52429); -- 1.05 MB (rounded to 2 decimals)
Example 5: Full range of supported units.
SELECT format_bytes(512);                    -- 512 B
SELECT format_bytes(2048); -- 2.00 KB
SELECT format_bytes(1572864); -- 1.50 MB
SELECT format_bytes(2147483648); -- 2.00 GB
SELECT format_bytes(1099511627776); -- 1.00 TB
SELECT format_bytes(1125899906842624); -- 1.00 PB
SELECT format_bytes(1152921504606846976); -- 1.00 EB
keyword
FORMAT_BYTES
