Version: Candidate-4.1
ST_Distance_Sphere
Calculates the spherical distance between two points on the Earth in "meters". The parameters inputted are longitude at X, latitude at X, longitude at Y, latitude at Y.
DOUBLE ST_Distance_Sphere(DOUBLE x_lng, DOUBLE x_lat, DOUBLE y_lng, DOUBLE x_lat)
MySQL > select st_distance_sphere(116.35620117, 39.939093, 116.4274406433, 39.9020987219);
| st_distance_sphere(116.35620117, 39.939093, 116.4274406433, 39.9020987219) |
| 7336.9135549995917 |
keyword​
ST_DISTANCE_SPHERE,ST,DISTANCE,SPHERE
