Version: Candidate-4.1
lookup_string
lookup_string(table_name, lookup_key, return_column)
This function looks up a value from a primary key table and evaluates it in the optimizer.
Arguments​
table_name: The name of the table to lookup. Must be a primary-key table (VARCHAR). lookup_key: The key to lookup. Must be a string type (VARCHAR). return_column: The name of the column to return (VARCHAR).
Return Value​
Returns a VARCHAR string containing the looked-up value. Returns NULL if not found.
Example 1: Return t2 table's event_day column value of t2 table with its primay key value equals to 1;
mysql> select lookup_string('t2', '1', 'event_day');
| lookup_string('t2', '1', 'event_day') |
| 2020-01-14 |
1 row in set (0.02 sec)
