Version: Candidate-4.1
inspect_task_runs
inspect_task_runs()
This function returns all status about the TaskManager.
Arguments​
None.
Return Value​
Returns a VARCHAR string containing the TaskManager status in JSON format.
Example 1: Inspect current TaskManger global pending/running task runs information:
mysql> select inspect_task_runs();
| inspect_task_runs() |
| {"pendingTaskRunQueue":{"pendingTaskRunMap":{},"pendingTaskRunQueue":[]},"runningTaskRunMap":{},"runningSyncTaskRunMap":{}} |
