Version: Candidate-4.1
inspect_mv_plan
inspect_mv_plan(mv_name) inspect_mv_plan(mv_name, use_cache)
These functions return the logical plan of a materialized view.
Arguments​
mv_name: The name of the materialized view (VARCHAR). use_cache: (Optional) A boolean value indicating whether to use the materialized view plan cache. Defaults to TRUE.
Return Value​
Returns a VARCHAR string containing the logical plan of the materialized view.
Example 1: Inspect a materialized view's logical plan using the plan cache:
mysql> select inspect_mv_plan('mv_on_view_1');
| inspect_mv_plan('mv_on_view_1') |
| plan 0:
LogicalAggregation {type=GLOBAL ,aggregations={3: sum=sum(2: pv)} ,groupKeys=[1: event_day] ,projection=null ,predicate=null}
-> LogicalOlapScanOperator {table=28673, selectedPartitionId=null, selectedIndexId=28674, outputColumns=[1: event_day, 2: pv], predicate=null, prunedPartitionPredicates=[], limit=-1}
plan 1:
LogicalViewScanOperator {table='view1', outputColumns='[4: event_day, 5: sum_pv]'}
Example 2: Inspect a materialized view's logical plan without using the plan cache:
mysql> select inspect_mv_plan('mv_on_view_1', false);
| inspect_mv_plan('mv_on_view_1', FALSE) |
| plan 0:
plan 1:
