Version: Candidate-4.1
inspect_memory_detail
inspect_memory_detail(module_name, class_info)
This function returns the estimated memory usage for a specific class or field within a module.
Arguments​
module_name: The name of the module (VARCHAR). class_info: The name of the class or 'class_name.field_name' (VARCHAR).
NOTE:
  1. The following module names are supported (for more details, see the MemoryUsageTracker.java class):
  • Load
  • Compaction
  • Export
  • Delete
  • Transaction
  • Backup
  • Task
  • TabletInvertedIndex
  • LocalMetastore
  • Report
  • MV
  • Query
  • Profile
  • Agent
  • Statistics
  • Coordinator
  • Dict
  1. class_info can be a class or a class's field of the specific class(for more details, see the MemoryUsageTracker.java class).
Return Value​
Returns a VARCHAR string representing the estimated memory size (e.g., "100MB").
Example 1: Inspect Task module TaskManager's memory usage:
mysql> select inspect_memory_detail('Task', 'TaskManager');
| inspect_memory_detail('Task', 'TaskManager') |
| 0B |
Example 2: Inspect Task module TaskManager's taskRunManager field's memory usage:
mysql> select inspect_memory_detail('Task', 'TaskManager.taskRunManager');
| inspect_memory_detail('Task', 'TaskManager.taskRunManager') |
| 592B |
