Version: Candidate-4.1
inspect_memory
inspect_memory(module_name)
This function returns the estimated memory usage for a specified module.
Arguments​
module_name: The name of the module (VARCHAR).
NOTE: The following module names are supported (for more details, see the MemoryUsageTracker.java class):
  • Load
  • Compaction
  • Export
  • Delete
  • Transaction
  • Backup
  • Task
  • TabletInvertedIndex
  • LocalMetastore
  • Report
  • MV
  • Query
  • Profile
  • Agent
  • Statistics
  • Coordinator
  • Dict
Return Value​
Returns a VARCHAR string representing the estimated memory size (e.g., "100MB").
Example 1: Inspect current FE's Load module memory usage:
mysql> SELECT inspect_memory('Load');
| inspect_memory('Load') |
| 251.8KB |
