get_query_dump
get_query_dump(query) get_query_dump(query, enable_mock)
These functions return a dump of the query for debugging purposes.
Arguments​
query: The SQL query string (VARCHAR). enable_mock: (Optional) A boolean value indicating whether to enable mock data for the dump. Defaults to FALSE.
Return Value​
Returns a VARCHAR string containing the query dump.
Example 1: Get a simple query's dump without mocking data
mysql> select get_query_dump('select * from ss limit 1');
1 row in set (0.04 sec)
