cos_similarity
Measures the similarity of two vectors by calculating the cosine of the angle between them. The angle is formed by the direction of the vectors while the difference in their magnitude is ignored.
The similarity is between -1 and 1. Smaller angles between vectors indicate greater cosine similarity.
  • If two vectors have the same direction, they have a 0-degree angle and the cosine similarity is 1.
  • Perpendicular vectors have a 90-degree angle and a cosine similarity of 0.
  • Opposite vectors have a 180-degree angle and a cosine similarity of -1.
cosine_similarity is commonly used for assessing text and video similarity.
This function normalizes vectors before measuring the cosine similarity. If the input vectors have been normalized, you can use cosine_similarity_norm.
cosine_similarity(a, b)
a and b are the vectors to compare. They must have the same dimension. The supported data type is Array<float>. The two arrays must have the same number of elements. Otherwise, an error is returned.
Returns a FLOAT value within the range of [-1, 1]. If any input parameter is null or invalid, an error is reported.
  1. Create a table to store vectors and insert data into this table.
    CREATE TABLE t1_similarity
    (id int, data array<float>)
    DISTRIBUTED BY HASH(id);
  2. Calculate the similarity of each row in the data column compared to the array [0.1, 0.2, 0.3] and list the result in descending order.
    SELECT id, data, cosine_similarity([0.1, 0.2, 0.3], data) as dist
    FROM t1_similarity
    ORDER BY dist DESC;
    | id | data | dist |
    | 1 | [0.1,0.2,0.3] | 0.9999999 |
    | 2 | [0.2,0.1,0.3] | 0.9285713 |
    | 3 | [0.3,0.2,0.1] | 0.7142856 |
