Version: Candidate-4.1
bitmap_intersect
Aggregation function, used to calculate the bitmap intersection after grouping. Common usage scenarios, such as calculating user retention rate.
BITMAP BITMAP_INTERSECT(BITMAP value)
Enter a set of bitmap values, find the intersection of this set of bitmap values, and return the result.
Example​
Table structure
KeysType: AGG_KEY
Columns: tag varchar, date datetime, user_id bitmap bitmap_union
-- Calculate users retention under different tags today and yesterday.
select tag, bitmap_intersect(user_id)
from (
select tag, date, bitmap_union(user_id) user_id
from table
where date in ('2020-05-18', '2020-05-19')
group by tag, date) a
group by tag;
Use with bitmap_to_string function to obtain the specific data of the intersection.
--Find out users retained under different tags today and yesterday.
select tag, bitmap_to_string(bitmap_intersect(user_id))
from (
from table where date in ('2020-05-18', '2020-05-19')
group by tag;
keyword​
BITMAP_INTERSECT, BITMAP
