to_binary
Converts a VARCHAR string to a binary value based on the specified binary format (binary_type) of the input string. The following binary formats are supported: hex, encode64, and utf8. If no binary_type is specified, hex is the default.
to_binary(str[, binary_type])
  • str: the string to convert, required. It must be a VARCHAR string.
  • binary_type: the binary format for conversion, optional.
    • hex(default): to_binary assumes the input string is a hex string in which all characters are in '0123456789abcdef'. If the input string is not valid, an empty binary is returned (exceptions will not be thrown). to_binary will convert the input string into binary directly. For example, "abab" will be converted to x'abab'. The input string is not case-sensitive.
    • encode64: to_binary assumes the input string is a base64-encoded string . If the input string is not valid, an empty binary is returned (exceptions will not be thrown). to_binary will decode the base64-encoded string as the binary result. For example, "YWJhYg==" will be converted to x'abab'.
    • utf8: to_binary converts the input string as a binary value without any transformation.
Returns a VARCHAR value.
The following examples assume that the --binary-as-hex option is enabled when you access StarRocks from your MySQL client. This way, binary data is displayed using hexadecimal notation.
mysql> select to_binary('ABAB', 'hex');
| to_binary('ABAB', 'hex') |
| 0xABAB |
mysql> select to_binary('U1RBUlJPQ0tT', 'encode64');
| to_binary('U1RBUlJPQ0tT', 'encode64') |
| 0x53544152524F434B53 |
mysql> select to_binary('STARROCKS', 'utf8');
| to_binary('STARROCKS', 'utf8') |
-- The input string does not match the binary format and an empty binary is returned.
mysql> select to_binary('U1RBUlJPQ0tT', 'hex');
| to_binary('U1RBUlJPQ0tT', 'hex') |
| 0x |
References​
