Version: Candidate-4.0
any_match
Returns whether any elements of an array match the given predicate.
  • Returns true (1) if one or more elements match the predicate.
  • Returns false (0) if none of the elements matches (a special case is when the array is empty).
  • Returns NULL if the predicate returns NULL for one or more elements and false for all other elements.
This function is supported from v3.0.6 onwards.
any_match(lambda_function, arr1, arr2...)
Returns whether any elements of arr1 match the given predicate in the lambda function.
  • arr1: the array to match.
  • arrN: optional arrays used in the lambda function.
  • lambda_function: the lambda function used to match values.
Returns a BOOLEAN value.
Usage notes​
  • The lambda function follows the usage notes in array_map().
  • If the input array is null or the lambda function results in null, null is returned.
  • If arr1 is empty, false is returned.
  • To apply this function to MAP, rewrite any_match((k,v)->k>v,map) to any_match(map_values(transform_values((k,v)->k>v, map))). For example, select any_match(map_values(transform_values((k,v)->k>v, map{2:1}))); returns 1.
Check whether any element in x is less than the elements in y.
select any_match((x,y) -> x < y, [1,2,8], [4,5,6]);
| any_match((x, y) -> x < y, [1, 2, 8], [4, 5, 6]) |
select any_match((x,y) -> x < y, [11,12,8], [4,5,6]);
| any_match((x, y) -> x < y, [11, 12, 8], [4, 5, 6]) |
| 0 |
select any_match((x,y) -> x < y, [11,12,null], [4,5,6]);
| any_match((x, y) -> x < y, [11, 12, NULL], [4, 5, 6]) |
select any_match((x,y) -> x < y, [], []);
| any_match((x, y) -> x < y, [], []) |
| 0 |
select any_match((x,y) -> x < y, null, [4,5,6]);
| any_match((x, y) -> x < y, NULL, [4, 5, 6]) |
