System variables
If you want to make a setting change for the current session and also make that setting change apply to all future sessions, you can make the change twice, once without the
GLOBALmodifier and once with it. For example:SET query_mem_limit = 137438953472; -- Apply to the current session.
Variable hierarchy and types
- Global variables take effect on global level, and can be overridden by session variables and
SET_VARhints. - Session variables take effect only on the current session, and can be overridden by
SET_VARhints. SET_VARhints take effect only on the current query statement.
View variables
SHOW VARIABLES;
Set variables
Set variables globally or for a single session
SET forward_to_master = true;
- activate_all_roles_on_login
- character_set_database
- default_rowset_type
- enable_query_queue_select
- enable_query_queue_load
- init_connect
- lower_case_table_names
- license
- language
- query_cache_size
- system_time_zone
- version_comment
- version
Set variables in a single query statement
- SELECT
- INSERT (from v3.1.12 and v3.2.0 onwards)
- UPDATE (from v3.1.12 and v3.2.0 onwards)
- DELETE (from v3.1.12 and v3.2.0 onwards)
Example:
UPDATE /*+ SET_VAR(query_timeout=100) */ tbl SET c1 = 2 WHERE c1 = 1;
FROM my_table PARTITION p1
WHERE k1 = 3;
INSERT /*+ SET_VAR(query_timeout = 10000000) */
INTO insert_wiki_edit
SELECT * FROM FILES(
"format" = "parquet",
"aws.s3.region" = "us-west-2"
SELECT /*+ SET_VAR
query_timeout=10000000,
batch_size=4096,
*/ * FROM TABLE;
Set variables as user properties
Example:
Descriptions of variables
- Description: Whether to enable all roles (including default roles and granted roles) for a StarRocks user when the user connects to the StarRocks cluster.
- If enabled (
true), all roles of the user are activated at user login. This takes precedence over the roles set by SET DEFAULT ROLE. - If disabled (
false), the roles set by SET DEFAULT ROLE are activated.
- If enabled (
- Default: false
- Introduced in: v3.0
auto_increment_increment
autocommit
chunk_size
- Description: Used to specify the number of rows of a single packet transmitted by each node during query execution. The default is 4096, i.e., every 4096 rows of data generated by the source node is packaged and sent to the destination node. A larger number of rows will improve the query throughput in large data volume scenarios, but may increase the query latency in small data volume scenarios. Also, it may increase the memory overhead of the query. We recommend to set
batch_sizebetween 1024 to 4096. - Default: 4096
big_query_profile_threshold
Description: Used to set the threshold for big queries. When the session variable
enable_profileis set tofalseand the amount of time taken by a query exceeds the threshold specified by the variablebig_query_profile_threshold, a profile is generated for that query.Note: In versions v3.1.5 to v3.1.7, as well as v3.2.0 to v3.2.2, we introduced the
big_query_profile_second_thresholdfor setting the threshold for big queries. In versions v3.1.8, v3.2.3, and subsequent releases, this parameter has been replaced bybig_query_profile_thresholdto offer more flexible configuration options. -
Default: 0
Unit: Second
Data type: String
Introduced in: v3.1
catalog
- Description: Used to specify the catalog to which the session belongs.
- Default: default_catalog
- Data type: String
- Introduced in: v3.2.4
- Description: Controls how the CBO converts data from the DECIMAL type to the STRING type. If this variable is set to
true, the logic built in v2.5.x and later versions prevails and the system implements strict conversion (namely, the system truncates the generated string and fills 0s based on the scale length). If this variable is set tofalse, the logic built in versions earlier than v2.5.x prevails and the system processes all valid digits to generate a string. - Default: true
- Introduced in: v2.5.14
- Description: Whether to enable low cardinality optimization. After this feature is enabled, the performance of querying STRING columns improves by about three times.
- Default: true
cbo_eq_base_type
- Description: Specifies the data type used for data comparison between DECIMAL data and STRING data. The default value is
VARCHAR, and DECIMAL is also a valid value. This variable takes effect only for=and!=comparison. - Data type: String
cbo_materialized_view_rewrite_related_mvs_limit
- Description: Specifies the maximum number of candidate materialized views allowed during query planning.
- Default: 64
- Introduced in: v3.1.9, v3.2.5
cbo_prune_subfield
- Description: Whether to enable JSON subfield pruning. This variable must be used with the BE dynamic parameter
enable_json_flat. Otherwise, it may degrade JSON data query performance. - Default: false
- Data type: Int
- Introduced in: v3.3.0
- Description: Whether to enable query rewrite based on synchronous materialized views.
- Default: true
- Introduced in: v3.1.11, v3.2.5
query_including_mv_names
- Description: Specifies the name of the asynchronous materialized views to include in query execution. You can use this variable to limit the number of candidate materialized views and improve the query rewrite performance in the optimizer. This item takes effect prior to
query_excluding_mv_names. - Default: empty
- Data type: String
- Description: Specifies the name of the asynchronous materialized views to exclude from query execution. You can use this variable to limit the number of candidate materialized views and reduce the time of query rewrite in the optimizer.
query_including_mv_namestakes effect prior to this item. - Default: empty
- Data type: String
- Description: Specifies the maximum time that one materialized view rewrite rule can consume. When the threshold is reached, this rule will not be used for query rewrite.
- Default: 1000
- Unit: ms
- Description: Whether to enable aggregation pushdown for materialized view query rewrite. If it is set to
true, aggregate functions will be pushed down to Scan Operator during query execution and rewritten by the materialized view before the Join Operator is executed. This will relieve the data expansion caused by Join and thereby improve the query performance. For detailed information about the scenarios and limitations of this feature, see Aggregation pushdown. - Default: false
- Description: Whether to enable text-based materialized view rewrite. When this item is set to true, the optimizer will compare the query with the existing materialized views. A query will be rewritten if the abstract syntax tree of the materialized view's definition matches that of the query or its sub-query.
- Default: true
- Introduced in: v3.2.5, v3.3.0
- Description: Specifies the maximum number of times that the system checks whether a query's sub-query matches the materialized views' definition.
- Default: 4
- Description: Whether to enable query rewrite for queries against multiple tables in the optimizer's rule-based optimization phase. Enabling this feature will improve the robustness of the query rewrite. However, it will also increase the time consumption if the query misses the materialized view.
- Default: true
enable_view_based_mv_rewrite
- Description: Whether to enable query rewrite for logical view-based materialized views. If this item is set to
true, the logical view is used as a unified node to rewrite the queries against itself for better performance. If this item is set tofalse, the system transcribes the queries against logical views into queries against physical tables or materialized views and then rewrites them. - Default: false
- Introduced in: v3.1.9, v3.2.5, v3.3.0
- Description: Whether to enable materialized view union rewrite. If this item is set to
true, the system seeks to compensate the predicates using UNION ALL when the predicates in the materialized view cannot satisfy the query's predicates. - Default: true
- Introduced in: v2.5.20, v3.1.9, v3.2.7, v3.3.0
- Description: Whether to enable materialized view plan cache, which can optimize the automatic rewrite performance of materialized views. Setting it to
trueindicates enabling it. - Default: true
- Introduced in: v2.5.13, v3.0.7, v3.1.4, v3.2.0, v3.3.0
enable_cbo_based_mv_rewrite
- Description: Whether to enable materialized view rewrite in CBO phase which can maximize the likelihood of successful query rewriting (e.g., when the join order differs between materialized views and queries), but it will increase the execution time of the optimizer phase.
- Default: true
- Introduced in: v3.5.5, v4.0.1
follower_query_forward_mode
Description: Specifies to which FE nodes the query statements are routed.
Valid values:
default: Routes the query statement to the Leader FE or Follower FEs, depending on the Follower's replay progress. If the Follower FE nodes have not completed replay progress, queries will be routed to the Leader FE node. If the replay progress is complete, queries will be preferentially routed to the Follower FE node.leader: Routes the query statement to the Leader FE.follower: Routes the query statement to Follower FE.
Default: default
Data type: String
- Data type: StringThe character set supported by StarRocks. Only UTF8 (
utf8) is supported. - Default: utf8
- Data type: String
- Description: The maximum number of concurrent I/O tasks that can be issued by a scan operator during external table queries. The value is an integer. Currently, StarRocks can adaptively adjust the number of concurrent I/O tasks when querying external tables. This feature is controlled by the variable
enable_connector_adaptive_io_tasks, which is enabled by default. - Default: 16
- Data type: Int
- Description: Specifies the compression algorithm used for writing data into Hive tables or Iceberg tables, or exporting data with Files().
- Valid values:
uncompressed,snappy,lz4,zstd, andgzip. - Default: uncompressed
- Data type: String
- Introduced in: v3.2.3
- Description: Specifies the maximum size of target file for writing data into Hive tables or Iceberg tables, or exporting data with Files(). The limit is not exact and is applied on a best-effort basis.
- Unit: Bytes
- Default: 1073741824
- Data type: Long
count_distinct_column_buckets
- Description: The number of buckets for the COUNT DISTINCT column in a group-by-count-distinct query. This variable takes effect only when
enable_distinct_column_bucketizationis set totrue. - Default: 1024
default_rowset_type (global)
default_table_compression
Description: The default compression algorithm for table storage. Supported compression algorithms are
snappy, lz4, zlib, zstd.Note that if you specified the
compressionproperty in a CREATE TABLE statement, the compression algorithm specified bycompressiontakes effect. -
Default: lz4_frame
Introduced in: v3.0
disable_colocate_join
- Description: Used to control whether the Colocation Join is enabled. The default value is
false, meaning the feature is enabled. When this feature is disabled, query planning will not attempt to execute Colocation Join. - Default: false
div_precision_increment
- Description: Whether to populate the data cache in asynchronous mode. By default, the system uses the synchronous mode to populate data cache, that is, populating the cache while querying data.
- Default: false
- Introduced in: v3.2.7
- Description: Whether to adaptively adjust the number of concurrent I/O tasks when querying external tables. Default value is
true. If this feature is not enabled, you can manually set the number of concurrent I/O tasks using the variableconnector_io_tasks_per_scan_operator. - Default: true
Description: Whether to enable bucketization for the COUNT DISTINCT colum in a group-by-count-distinct query. Use the
select a, count(distinct b) from t group by a;query as an example. If the GROUP BY columais a low-cardinality column and the COUNT DISTINCT columnbis a high-cardinality column which has severe data skew, performance bottleneck will occur. In this situation, you can split data in the COUNT DISTINCT column into multiple buckets to balance data and prevent data skew. You must use this variable with the variablecount_distinct_column_buckets.You can also enable bucketization for the COUNT DISTINCT column by adding the
skewhint to your query, for example,select a,count(distinct [skew] b) from t group by a;. -
Default: false, which means this feature is disabled.
Introduced in: v2.5
enable_gin_filter
- Description: Whether to utilize the fulltext inverted index during queries.
- Default: true
enable_group_execution
- Description: Whether to enable Colocate Group Execution. Colocate Group Execution is an execution pattern that leverages physical data partitioning, where a fixed number of threads sequentially process their respective data ranges to enhance locality and throughput. Enabling this feature can reduce memory usage.
- Default: true
- Description: Whether to enable resource group-level query queue.
- Default: false, which means this feature is disabled.
- Introduced in: v3.1.4
enable_insert_partial_update
- Description: Whether to enable Partial Update for INSERT statements on Primary Key tables. When this item is set to
true(default), if an INSERT statement specifies only a subset of columns (fewer than the number of all non-generated columns in the table), the system performs a Partial Update to update only the specified columns while preserving existing values in other columns. When set tofalse, the system uses default values for unspecified columns instead of preserving existing values. This feature is particularly useful for updating specific columns in Primary Key tables without affecting other column values. - Default: true
- Introduced in: v3.3.20, v3.4.9, v3.5.8, v4.0.2
enable_iceberg_metadata_cache
- Description: Whether to cache pointers and partition names for Iceberg tables. From v3.2.1 to v3.2.3, this parameter is set to
trueby default, regardless of what metastore service is used. In v3.2.4 and later, if the Iceberg cluster uses AWS Glue as metastore, this parameter still defaults totrue. However, if the Iceberg cluster uses other metastore service such as Hive metastore, this parameter defaults tofalse. - Introduced in: v3.2.1
enable_metadata_profile
- Description: 是否为 Iceberg Catalog 的元数据收集查询开启 Profile。
- Default: true
- Introduced in: v3.3.3
plan_mode
- Description: The metadata retrieval strategy of Iceberg Catalog. For more information, see Iceberg Catalog metadata retrieval strategy. Valid values:
auto: The system will automatically select the retrieval plan.local: Use the local cache plan.distributed: Use the distributed plan.
- Default: auto
- Description: The timeout duration for Iceberg Catalog metadata collection queries.
- Unit: Second
- Default: 60
enable_insert_strict
Used to enable the strict mode when loading data using the INSERT statement. The default value is true, indicating the strict mode is enabled by default. For more information, see Strict mode.
- Description: Whether to allow StarRocks to rewrite queries in INSERT INTO SELECT statements.
- Default: false, which means Query Rewrite in such scenarios is disabled by default.
- Introduced in: v2.5.18, v3.0.9, v3.1.7, v3.2.2
- Description: Controls whether to enable rule-based materialized view query rewrite. This variable is mainly used in single-table query rewrite. * Default: true
- Data type: Boolean
enable_short_circuit
- Description: Whether to enable short circuiting for queries. Default:
false. If it is set totrue, when the query meets the criteria (to evaluate whether the query is a point query): the conditional columns in the WHERE clause include all primary key columns, and the operators in the WHERE clause are=orIN, the query takes the short circuit. - Default: false
enable_parallel_merge
- Description: Whether to enable parallel merge for sorting. When this feature is enabled, the merge phase of sorting will utilize multiple threads for merge operations.
- Default: true
enable_per_bucket_optimize
- Description: Whether to enable bucketed computation. When this feature is enabled, stage-one aggregation can be computed in bucketed order, reducing memory usage.
- Default: true
enable_spill
- Description: Whether to enable intermediate result spilling. Default:
false. If it is set totrue, StarRocks spills the intermediate results to disk to reduce the memory usage when processing aggregate, sort, or join operators in queries. - Default: false
enable_spill_to_remote_storage
- Description: Whether to enable intermediate result spilling to object storage. If it is set to
true, StarRocks spills the intermediate results to the storage volume specified inspill_storage_volumeafter the capacity limit of the local disk is reached. For more information, see Spill to object storage. - Default: false
enable_strict_order_by
- Description: Used to check whether the column name referenced in ORDER BY is ambiguous. When this variable is set to the default value
TRUE, an error is reported for such a query pattern: Duplicate alias is used in different expressions of the query and this alias is also a sorting field in ORDER BY, for example,select distinct t1.* from tbl1 t1 order by t1.k1;. The logic is the same as that in v2.3 and earlier. When this variable is set toFALSE, a loose deduplication mechanism is used, which processes such queries as valid SQL queries. - Default: true
- Introduced in: v2.5.18 and v3.1.7
enable_profile
Description: Specifies whether to send the profile of a query for analysis. The default value is
false, which means no profile is required.By default, a profile is sent to the FE only when a query error occurs in the BE. Profile sending causes network overhead and therefore affects high concurrency.
If you need to analyze the profile of a query, you can set this variable to
true. After the query is completed, the profile can be viewed on the web page of the currently connected FE (address:fe_host:fe_http_port/query). This page displays the profiles of the latest 100 queries withenable_profileturned on. -
Default: false
- Description: Boolean value to enable query queues for loading tasks.
- Default: false
- Description: Whether to enable query queues for SELECT queries.
- Default: false
- Description: Whether to enable query queues for statistics queries.
- Default: false
enable_query_tablet_affinity
Description: Boolean value to control whether to direct multiple queries against the same tablet to a fixed replica.
However, if there are some hotspot tablets, this feature may degrade the query performance because it directs the queries to the same BE, making it unable to fully use the resources of multiple BEs in high-concurrency scenarios.
Default: false, which means the system selects a replica for each query.
Introduced in: v2.5.6, v3.0.8, v3.1.4, and v3.2.0.
- Description: Whether to enable Parallel Scan for Cloud-native tables in a shared-data cluster.
- Default: false
tablet_internal_parallel_mode
- Description: Internal Parallel Scan strategy of tablets. Valid Values:
auto: When the number of Tablets to be scanned on BE or CN nodes is less than the Degree of Parallelism (DOP), the system automatically determines whether Parallel Scan is needed based on the estimated size of the Tablets.force_split: Forces the splitting of Tablets and performs Parallel Scan.
- Default: auto
- Data type: String
- Introduced in: v2.5.0
enable_scan_datacache
- Description: Specifies whether to enable the Data Cache feature. After this feature is enabled, StarRocks caches hot data read from external storage systems into blocks, which accelerates queries and analysis. For more information, see Data Cache. In versions prior to 3.2, this variable was named as
enable_scan_block_cache. - Default: true
populate_datacache_mode
- Description: Specifies the population behavior of Data Cache when reading data blocks from external storage systems. Valid values:
auto(default): the system automatically caches data selectively based on the population rule.always: Always cache the data.never: Never cache the data.
- Default: auto
enable_datacache_io_adaptor
- Description: Whether to enable the Data Cache I/O Adaptor. Setting this to
trueenables the feature. When this feature is enabled, the system automatically routes some cache requests to remote storage when the disk I/O load is high, reducing disk pressure. - Default: true
enable_file_metacache
- Description: Whether to enable metadata cache for files in remote storage (Footer Cache). Setting this to
trueenables the feature. Footer Cache directly caches the parsed Footer object in memory. When the same file's Footer is accessed in subsequent queries, the object descriptor can be obtained directly from the cache, avoiding repetitive parsing. This feature uses the memory module of the Data Cache for data caching. Therefore, you must ensure that the BE parameterdatacache_enableis set totrueand configure a reasonable value fordatacache_mem_size. - Default: true
- Description: Whether to enable adaptive parallel scanning of tablets. After this feature is enabled, multiple threads can be used to scan one tablet by segment, increasing the scan concurrency.
- Default: true
- Introduced in: v2.3
enable_query_cache
- Description: Specifies whether to enable the Query Cache feature. Valid values: true and false.
truespecifies to enable this feature, andfalsespecifies to disable this feature. When this feature is enabled, it works only for queries that meet the conditions specified in the application scenarios of Query Cache. - Default: false
enable_adaptive_sink_dop
- Description: Specifies whether to enable adaptive parallelism for data loading. After this feature is enabled, the system automatically sets load parallelism for INSERT INTO and Broker Load jobs, which is equivalent to the mechanism of
pipeline_dop. For a newly deployed v2.5 StarRocks cluster, the value istrueby default. For a v2.5 cluster upgraded from v2.4, the value isfalse. - Default: false
enable_pipeline_engine
- Description: Specifies whether to enable the pipeline execution engine.
trueindicates enabled andfalseindicates the opposite. Default value:true. - Default: true
enable_sort_aggregate
- Description: Specifies whether to enable sorted streaming.
trueindicates sorted streaming is enabled to sort data in data streams. - Default: false
enable_global_runtime_filter
- If this feature is disabled, only Local RF works.
- If this feature is enabled, multi-column Global RF takes effect and carries
multi-columnin the partition by clause.
- Description: Whether to allow for sinking data to external tables of Hive.
- Default: false
event_scheduler
enable_strict_type
- Description: Whether to allow implicit conversions for all compound predicates and for all expressions in the WHERE clause.
- Default: false
force_streaming_aggregate
forward_to_leader
SHOW FRONTENDS: Forwarding to the leader FE allows users to view the last heartbeat message.
SHOW BACKENDS: Forwarding to the leader FE allows users to view the boot time, last heartbeat information, and disk capacity information.
SHOW BROKER: Forwarding to the leader FE allows users to view the boot time and last heartbeat information.
SHOW TABLET
ADMIN SHOW REPLICA STATUS: Forwarding to the leader FE allows users to view the tablet information stored in the metadata of the leader FE. Normally, the tablet information should be the same in the metadata of different FEs. If an error occurs, you can use this method to compare the metadata of the current FE and the leader FE.
Show PROC: Forwarding to the leader FE allows users to view the PROC information stored in the metadata. This is mainly used for metadata comparison.
group_concat_max_len
- Description: The maximum length of string returned by the group_concat function.
- Default: 1024
- Min value: 4
- Unit: Characters
- Data type: Long
group_execution_max_groups
- Description: Maximum number of groups allowed for Group Execution. It is used to limit the granularity of splitting, preventing excessive scheduling overhead caused by an excessive number of groups.
- Default: 128
group_execution_min_scan_rows
- Description: Minimum number of rows processed per group for Group Execution.
- Default: 5000000
- Description: Used to control whether the data of the left table can be filtered by using the filter condition against the right table in the Join query. If so, it can reduce the amount of data that needs to be processed during the query.
Default:
trueindicates the operation is allowed and the system decides whether the left table can be filtered.falseindicates the operation is disabled. The default value istrue.
init_connect (global)
interactive_timeout
interpolate_passthrough
- Description: Whether to add local-exchange-passthrough for certain operators. Currently supported operators include streaming aggregates, etc. Adding local-exchange can mitigate the impact of data skew on computation, but will slightly increase memory usage.
- Default: true
- Description: The number of concurrent I/O tasks that can be issued by a scan operator. Increase this value if you want to access remote storage systems such as HDFS or S3 but the latency is high. However, a larger value causes more memory consumption.
- Default: 4
- Data type: Int
jit_level
- Description: The level at which JIT compilation for expressions is enabled. Valid values:
1: The system adaptively enables JIT compilation for compilable expressions.-1: JIT compilation is enabled for all compilable, non-constant expressions.0: JIT compilation is disabled. You can disable it manually if any error is returned for this feature.
- Default: 1
- Data type: Int
- Introduced in: -
language (global)
license (global)
- Description: Displays the license of StarRocks.
- Default: Apache License 2.0
load_mem_limit
log_rejected_record_num (v3.1 and later)
- The value
0specifies that data rows that are filtered out will not be logged. - The value
-1specifies that all data rows that are filtered out will be logged. - A non-zero positive integer such as
nspecifies that up tondata rows that are filtered out can be logged on each BE.
materialized_view_rewrite_mode (v3.2 and later)
disable: Disable automatic query rewrite of asynchronous materialized views.default(Default value): Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, it directly scans the data in the base table.default_or_error: Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, an error is returned.force: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, it directly scans the data in the base table.force_or_error: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, an error is returned.
max_allowed_packet
- Description: Used for compatibility with the JDBC connection pool C3P0. This variable specifies the maximum size of packets that can be transmitted between the client and server.
- Default: 33554432 (32 MB). You can raise this value if the client reports "PacketTooBigException".
- Unit: Byte
- Data type: Int
- Description: The maximum number of predicates that can be pushed down for a column.
- Default: -1, indicating that the value in the
be.conffile is used. If this variable is set to a value greater than 0, the value inbe.confis ignored. - Data type: Int
max_scan_key_num
- Description: The maximum number of scan key segmented by each query.
nested_mv_rewrite_max_level
- Description: The maximum levels of nested materialized views that can be used for query rewrite.
- Value range: [1, +∞). The value of
1indicates that only materialized views created on base tables can be used for query rewrite. - Default: 3
- Data type: Int
net_buffer_length
net_read_timeout
net_write_timeout
new_planner_optimize_timeout
- Description: The timeout duration of the query optimizer. When the optimizer times out, an error is returned and the query is stopped, which affects the query performance. You can set this variable to a larger value based on your query or contact StarRocks technical support for troubleshooting. A timeout often occurs when a query has too many joins.
- Default: 3000
- Unit: ms
