Version: Stable-3.3
About Routine Load​
Routine load is a method using Apache Kafka, or in this lab, Redpanda, to continuously stream data into StarRocks. The data is streamed into a Kafka topic, and a Routine Load job consumes the data into StarRocks. More details on Routine Load are provided at the end of the lab.
About shared-data​
In systems that separate storage from compute, data is stored in low-cost reliable remote storage systems such as Amazon S3, Google Cloud Storage, Azure Blob Storage, and other S3-compatible storage like MinIO. Hot data is cached locally and when the cache is hit, the query performance is comparable to that of storage-compute coupled architecture. Compute nodes (CN) can be added or removed on demand within seconds. This architecture reduces storage costs, ensures better resource isolation, and provides elasticity and scalability.
This tutorial covers:
  • Running StarRocks, Redpanda, and MinIO with Docker Compose
  • Using MinIO as the StarRocks storage layer
  • Configuring StarRocks for shared-data
  • Adding a Routine Load job to consume data from Redpanda
The data used is synthetic.
There is a lot of information in this document, and it is presented with step-by-step content at the beginning, and the technical details at the end. This is done to serve these purposes in this order:
  1. Configure Routine Load.
  2. Allow the reader to load data in a shared-data deployment and analyze that data.
  3. Provide the configuration details for shared-data deployments.
Prerequisites​
Docker​
  • Docker
  • 4Β GB RAM assigned to Docker
  • 10 GB free disk space assigned to Docker
SQL client​
You can use the SQL client provided in the Docker environment, or use one on your system. Many MySQL-compatible clients will work, and this guide covers the configuration of DBeaver and MySQL Workbench.
curl​
curl is used to download the Compose file and the script to generate the data. Check to see if you have it installed by running curl or curl.exe at your OS prompt. If curl is not installed, get curl here.
Python​
Python 3 and the Python client for Apache Kafka, kafka-python, are required.
Terminology​
FE​
Frontend nodes are responsible for metadata management, client connection management, query planning, and query scheduling. Each FE stores and maintains a complete copy of metadata in its memory, which guarantees indiscriminate services among the FEs.
CN​
Compute Nodes are responsible for executing query plans in shared-data deployments.
BE​
Backend nodes are responsible for both data storage and executing query plans in shared-nothing deployments.
note
This guide does not use BEs, this information is included here so that you understand the difference between BEs and CNs.
Launch StarRocks​
To run StarRocks with shared-data using Object Storage you need:
  • A frontend engine (FE)
  • A compute node (CN)
  • Object Storage
This guide uses MinIO, which is S3 compatible Object Storage provider. MinIO is provided under the GNU Affero General Public License.
Download the lab files​
docker-compose.yml​
mkdir routineload
cd routineload
gen.py​
gen.py is a script that uses the Python client for Apache Kafka to publish (produce) data to a Kafka topic. The script has been written with the address and port of the Redpanda container.
Start StarRocks, MinIO, and Redpanda​
Check the progress of the services. It should take 30 seconds or more for the containers to become healthy. The routineload-minio_mc-1 container will not show a health indicator, and it will exit once it is done configuring MinIO with the access key that StarRocks will use. Wait for routineload-minio_mc-1 to exit with a 0 code and the rest of the services to be Healthy.
Run docker compose ps until the services are healthy:
docker compose ps
[+] Running 6/7
βœ” Network routineload_default Crea... 0.0s
βœ” Container minio Healthy 5.6s
βœ” Container redpanda Healthy 3.6s
βœ” Container redpanda-console Healt... 1.1s
β § Container routineload-minio_mc-1 Waiting 23.1s
βœ” Container starrocks-fe Healthy 11.1s
βœ” Container starrocks-cn Healthy 23.0s
Examine MinIO credentials​
In order to use MinIO for Object Storage with StarRocks, StarRocks needs a MinIO access key. The access key was generated during the startup of the Docker services. To help you better understand the way that StarRocks connects to MinIO you should verify that the key exists.
Open the MinIO web UI​
Browse to http://localhost:9001/access-keys The username and password are specified in the Docker compose file, and are miniouser and miniopassword. You should see that there is one access key. The Key is AAAAAAAAAAAAAAAAAAAA, you cannot see the secret in the MinIO Console, but it is in the Docker compose file and is BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB:
View the MinIO access key
SQL Clients​
These three clients are tested with this tutorial, you only need one:
  • mysql CLI: You can run this from the Docker environment or your machine.
  • DBeaver is available as a community version and a Pro version.
  • MySQL Workbench
Configuring the client​
The easiest way to use the mysql CLI is to run it from the StarRocks container starrocks-fe:
tip
All docker compose commands must be run from the directory containing the docker-compose.yml file.
If you would like to install the mysql CLI expand mysql client install below:
  • macOS: If you use Homebrew and do not need MySQL Server run brew install mysql to install the CLI.
  • Linux: Check your repository system for the mysql client. For example, yum install mariadb.
  • Microsoft Windows: Install the MySQL Community Server and run the provided client, or run mysql from WSL.
StarRocks configuration for shared-data​
At this point you have StarRocks, Redpanda, and MinIO running. A MinIO access key is used to connect StarRocks and Minio. When StarRocks started up, it established the connection with MinIO and created the default storage volume in MinIO.
This is the configuration used to set the default storage volume to use MinIO (this is also in the Docker compose file). The configuration will be described in detail at the end of this guide, for now just note that the aws_s3_access_key is set to the string that you saw in the MinIO Console and that the run_mode is set to shared_data.
run_mode = shared_data
aws_s3_endpoint = minio:9000
# set the path in MinIO
aws_s3_path = starrocks
# credentials for MinIO object read/write
aws_s3_access_key = AAAAAAAAAAAAAAAAAAAA
aws_s3_secret_key = BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB
aws_s3_use_instance_profile = false
aws_s3_use_aws_sdk_default_behavior = false
# Set this to false if you do not want default
# storage created in the object storage using
# the details provided above
enable_load_volume_from_conf = true
tip
To see the full configuration file you can run this command:
docker compose exec starrocks-fe cat fe/conf/fe.conf
Run all docker compose commands from the directory containing the docker-compose.yml file.
Connect to StarRocks with a SQL client​
tip
Run this command from the directory containing the docker-compose.yml file.
If you are using a client other than the mysql CLI, open that now.
Examine the storage volume​
SHOW STORAGE VOLUMES;
| Storage Volume |
| builtin_storage_volume |
DESC STORAGE VOLUME builtin_storage_volume\G
tip
Some of the SQL in this document, and many other documents in the StarRocks documentation, and with \G instead of a semicolon. The \G causes the mysql CLI to render the query results vertically.
Many SQL clients do not interpret vertical formatting output, so you should replace \G with ;.
Type: S3
IsDefault: true
Params: {"aws.s3.access_key":"******","aws.s3.secret_key":"******","aws.s3.endpoint":"minio:9000","aws.s3.region":"","aws.s3.use_instance_profile":"false","aws.s3.use_aws_sdk_default_behavior":"false"}
Enabled: true
Comment:
1 row in set (0.03 sec)
Verify that the parameters match the configuration.
note
The folder builtin_storage_volume will not be visible in the MinIO object list until data is written to the bucket.
Create a table​
These SQL commands are run in your SQL client.
CREATE DATABASE quickstart;
USE quickstart;
CREATE TABLE site_clicks (
DISTRIBUTED BY HASH(`uid`)
Open the Redpanda Console​
There will be no topics yet, a topic will be created in the next step.
Publish data to a Redpanda topic​
From a command shell in the routineload/ folder run this command to generate data:
python gen.py 5
tip
On your system, you might need to use python3 in place of python in the command.
If you are missing kafka-python try:
pip install kafka-python
or
pip3 install kafka-python
Verify in the Redpanda Console​
Navigate to http://localhost:8080/topics in the Redpanda Console, and you will see one topic named test2. Select that topic and then the Messages tab and you will see five messages matching the output of gen.py.
Consume the messages​
In StarRocks you will create a Routine Load job to:
  1. Consume the messages from the Redpanda topic test2
  2. Load those messages into the table site_clicks
StarRocks is configured to use MinIO for storage, so the data inserted into the site_clicks table will be stored in MinIO.
Create a Routine Load job​
Run this command in the SQL client to create the Routine Load job, the command will be explained in detail at the end of the lab.
PROPERTIES
"format" = "JSON",
FROM KAFKA
"kafka_topic" = "test2",
"kafka_partitions" = "0",
Verify the Routine Load job​
SHOW ROUTINE LOAD\G
Verify the three highlighted lines:
  1. The state should be RUNNING
  2. The topic should be test2 and the broker should be redpanda:2092
  3. The statistics should show either 0 or 5 loaded rows depending on how soon you ran the SHOW ROUTINE LOAD command. If there are 0 loaded rows run it again.
PauseTime: NULL
EndTime: NULL
DbName: quickstart
TableName: site_clicks
State: RUNNING
DataSourceType: KAFKA
CurrentTaskNum: 1
Progress: {"0":"OFFSET_ZERO"}
TimestampProgress: {}
ReasonOfStateChanged:
ErrorLogUrls:
TrackingSQL:
OtherMsg:
LatestSourcePosition: {}
SHOW ROUTINE LOAD\G
PauseTime: NULL
EndTime: NULL
DbName: quickstart
State: RUNNING
CurrentTaskNum: 1
Progress: {"0":"4"}
ErrorLogUrls:
TrackingSQL:
OtherMsg:
Verify that data is stored in MinIO​
Open MinIO http://localhost:9001/browser/ and verify that there are objects stored under starrocks.
Query the data from StarRocks​
USE quickstart;
SELECT * FROM site_clicks;
| uid | site | vtime |
5 rows in set (0.07 sec)
Publish additional data​
Running gen.py again will publish another five records to Redpanda.
python gen.py 5
Verify that data is added​
Since the Routine Load job runs on a schedule (every 10 seconds by default), the data will be loaded within a few seconds.
10 rows in set (0.02 sec)
Configuration details​
Now that you have experienced using StarRocks with shared-data it is important to understand the configuration.
CN configuration​
The CN configuration used here is the default, as the CN is designed for shared-data use. The default configuration is shown below. You do not need to make any changes.
sys_log_level = INFO
be_port = 9060
be_http_port = 8040
heartbeat_service_port = 9050
brpc_port = 8060
starlet_port = 9070
FE configuration​
The FE configuration is slightly different from the default as the FE must be configured to expect that data is stored in Object Storage rather than on local disks on BE nodes.
The docker-compose.yml file generates the FE configuration in the command section of the starrocks-fe service.
note
This config file does not contain the default entries for an FE, only the shared-data configuration is shown.
The non-default FE configuration settings:
note
Many configuration parameters are prefixed with s3_. This prefix is used for all Amazon S3 compatible storage types (for example: S3, GCS, and MinIO). When using Azure Blob Storage the prefix is azure_.
run_mode=shared_data​
This enables shared-data use.
cloud_native_storage_type=S3​
This specifies whether S3 compatible storage or Azure Blob Storage is used. For MinIO this is always S3.
aws_s3_endpoint=minio:9000​
The MinIO endpoint, including port number.
aws_s3_path=starrocks​
The bucket name.
aws_s3_access_key=AAAAAAAAAAAAAAAAAAAA​
The MinIO access key.
aws_s3_secret_key=BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB​
The MinIO access key secret.
aws_s3_use_instance_profile=false​
When using MinIO an access key is used, and so instance profiles are not used with MinIO.
aws_s3_use_aws_sdk_default_behavior=false​
When using MinIO this parameter is always set to false.
enable_load_volume_from_conf=true​
When this is true, a StarRocks storage volume named builtin_storage_volume is created using MinIO object storage, and it is set to be the default storage volume for the tables that you create.
Notes on the Routine Load command​
StarRocks Routine Load takes many arguments. Only the ones used in this tutorial are described here, the rest will be linked to in the more information section.
PROPERTIES
"format" = "JSON",
FROM KAFKA
The parameters for CREATE ROUTINE LOAD ON are:
  • database_name.job_name
  • table_name
database_name is optional. In this lab, it is quickstart and is specified.
job_name is required, and is clicks
table_name is required, and is site_clicks
Job properties​
Property format​
"format" = "JSON",
In this case, the data is in JSON format, so the property is set to JSON. The other valid formats are: CSV, JSON, and Avro. CSV is the default.
Property jsonpaths​
The names of the fields that you want to load from JSON-formatted data. The value of this parameter is a valid JsonPath expression. More information is available at the end of this page.
Data source properties​
kafka_broker_list​
Kafka's broker connection information. The format is <kafka_broker_name_or_ip>:<broker_ port>. Multiple brokers are separated by commas.
kafka_topic​
The Kafka topic to consume from.
kafka_partitions and kafka_offsets​
These properties are presented together as there is one kafka_offset required for each kafka_partitions entry.
kafka_partitions is a list of one or more partitions to consume. If this property is not set, then all partitions are consumed.
kafka_offsets is a list of offsets, one for each partition listed in kafka_partitions. In this case the value is OFFSET_BEGINNING which causes all of the data to be consumed. The default is to only consume new data.
Summary​
In this tutorial you:
  • Deployed StarRocks, Reedpanda, and Minio in Docker
  • Created a Routine Load job to consume data from a Kafka topic
  • Learned how to configure a StarRocks Storage Volume that uses MinIO
More information​
StarRocks Architecture
The sample used for this lab is very simple. Routine Load has many more options and capabilities. learn more.
JSONPath
