Column-to-row conversion is a common operation in ETL processing. Lateral is a special Join keyword that can associate a row with an internal subquery or table function. By using Lateral in conjunction with unnest(), you can expand one row into multiple rows. For more information, see unnest.
Limitsβ
- Currently, Lateral Join is only used with unnest() to achieve column-to-row conversion. Other table functions and UDTFs will be supported later.
- Currently, Lateral Join does not support subqueries.
Use Lateral Joinβ
Syntax:
Examples:
SELECT student, score
FROM tests
The second syntax here is a shortened version of the first one, where the Lateral keyword can be omitted using the UNNEST keyword. The UNNEST keyword is a table function that converts an array into multiple rows. Together with Lateral Join, it can implement common row expansion logic.
If you want to perform unnest on multiple columns, you must specify an alias for each column, for example,
select v1, t1.unnest as v2, t2.unnest as v3 from lateral_test, unnest(v2) t1, unnest(v3) t2;
StarRocks supports type conversion among BITMAP, STRING, ARRAY, and Column.
Usage examplesβ
Together with unnest(), you can achieve the following column-to-row conversion features:
Expand a string into multiple rowsβ
Create a table and insert data into this table.
CREATE TABLE lateral_test2 (
`v2` string NULL COMMENT ""
DUPLICATE KEY(v1)
DISTRIBUTED BY HASH(`v1`) BUCKETS 1
"storage_format" = "DEFAULT"
INSERT INTO lateral_test2 VALUES (1, "1,2,3"), (2, "1,3"); -
Query data before expansion.
select * from lateral_test2;
| v1 | v2 |
| 1 | 1,2,3 |
| 2 | 1,3 |
Expand
v2
into multiple rows.-- Perform unnest on a single column.
| v1 | unnest |
| 1 | 1 |
| 1 | 2 |
| 1 | 3 |
| 2 | 1 |
| 2 | 3 |
-- Perform unnest on multiple columns. You must specify an alias for each operation.
| v1 | v2 | v3 |
| 1 | 1 | 1 |
| 1 | 1 | 2 |
| 1 | 2 | 1 |
| 1 | 2 | 2 |
| 1 | 3 | 1 |
| 1 | 3 | 2 |
| 2 | 1 | 1 |
| 2 | 1 | 3 |
| 2 | 3 | 1 |
| 2 | 3 | 3 |
Expand an array into multiple rowsβ
From v2.5, unnest() can take multiple arrays of different types and lengths. For more information, see unnest().
CREATE TABLE lateral_test (
`v2` ARRAY NULL COMMENT ""
DUPLICATE KEY(v1)
INSERT INTO lateral_test VALUES (1, [1,2]), (2, [1, null, 3]), (3, null); -
select * from lateral_test;
| v1 | v2 |
| 1 | [1,2] |
| 2 | [1,null,3] |
| 3 | NULL |
Expand
v2
into multiple rows.select v1,v2,unnest from lateral_test , unnest(v2) as unnest;
| v1 | v2 | unnest |
| 1 | [1,2] | 1 |
| 1 | [1,2] | 2 |
| 2 | [1,null,3] | 1 |
| 2 | [1,null,3] | NULL |
| 2 | [1,null,3] | 3 |
Expand Bitmap dataβ
CREATE TABLE lateral_test3 (
AGGREGATE KEY(v1)
DISTRIBUTED BY HASH(`v1`) BUCKETS 1;
INSERT INTO lateral_test3 VALUES (1, bitmap_from_string('1, 2')), (2, to_bitmap(3)); -
| 1 | 1,2 |
| 2 | 3 |
Insert a new row.
| 1 | 1,2,3 |
| 2 | 3 |
Expand data in
v2
into multiple rows.select v1,unnest from lateral_test3, unnest(bitmap_to_array(v2)) as unnest;
| v1 | unnest |
| 1 | 1 |
| 1 | 2 |
| 1 | 3 |
| 2 | 3 |
